Results 1 to 5 of 5
Thread: 06 LBZ PCM and TCM question
    Oct 2006
    Default 06 LBZ PCM and TCM question
    First post to this forum.
    Wanted to know when correcting the speedometer for larger/smaller tire, do you modify parameters in the PCM or TCM?
    Thanks in advance
    Ray
    Dec 2005
    pcm
    Sep 2006
    SStuner what programmer are you using for your 06
    SSTuner, welcome to the forum.
    Oct 2006
    I currently am beta testing the Edge Attitude, not happy at all. Can't change the speedometer. I want to buy EFILive as soon as it's released.
    I use LT1Edit(OBD1) and TunerCat (OBD1) on my 96 OBD2 to OBD1 converted supercharged/6-speed Impala SS.
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 10:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 02:22 PM
