Results 1 to 3 of 3
Thread: sample rate V2
    Oct 2005
    Default sample rate V2
    I would like to hook up a sensor to the V2 but need a sample rate of 10-100kHz. Will that be possible or do I need an external data logger?
    I'll need to get Paul to respond to this but I think the V2 could sample it no problem, but it will only get sent back to the PC with the OBDII data which will not give you your sample rates.
    I'm fairly sure that if you only select external PIDs, then the sample rate will be quite high, since it will not be bogged down by the OBDII data.
    I just tried with 1 A/D PID selected and got 40 frames per second. With 8 external PIDs selected I got 35 frames per second.
    Depending on the speed of your PC you will get better or worse than that.
  1. Map Sample rate {B2105}
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 2nd, 2010, 07:00 PM
  2. Sample Rate
    By DMaxME in forum General
    Last Post: October 14th, 2009, 08:59 AM
  3. newbee looking for some sample tunes
    By 03FullPull in forum Gen III V8 Specific
    Last Post: July 31st, 2008, 01:31 PM
  4. T42 TCC Apply Rate?
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 26th, 2008, 01:30 AM
  5. Sample Size for 3000+ RPM
    By 2002_z28_six_speed in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2007, 05:20 AM
