Results 1 to 4 of 4
Thread: V2 AFR display?
    Oct 2003
    Default V2 AFR display?
    If one were to buy a new wideband without a display such as the new PLX and they configured the proper PIDs, would V2 display the current AFR on it's baby blue screen?
    PowrMax Performance
    100 mm PowrMAF
    Jan 2005
    I believe so. Of course, it will be much easier to configure if you have the WB controller so you have the linear 0-5vdc signal.
    I run dual LC-1's with no gauge just fine. Although I haven't attempted to view it on V2 yet.
    Oct 2004
    It is planned, not yet though.
    Andrew
    EFILive Crew
    Oct 2003
    What I am thinking is that this $200 WB:
    http://www.plxdevices.com/products_SMAFR.htm
    With V2 would be a cheap WB solution for tuning, serve as a stand alone WB of sorts as well as a selling feature for V2.
    PowrMax Performance
    100 mm PowrMAF
  1. How to display names on DIC
    By LBZoom in forum General (Diesel)
    Last Post: April 15th, 2009, 11:30 AM
  2. Can't display more than 99,000 frames
    By XLR8NSS in forum General
    Last Post: July 11th, 2008, 07:47 AM
  3. Can't display in metric
    Last Post: April 16th, 2008, 01:51 AM
  4. self test, display
    By Wolfie in forum FlashScan V2
    Last Post: April 15th, 2008, 11:01 AM
  5. scantool display to use as dash display?
    By ace68 in forum Lounge
    Last Post: March 3rd, 2006, 06:50 AM
