I assume that some of these also apply to ETC vehicles as there are no ETC idle airflow PIDs? For example, "Desired IAC Airflow" can be said to also = Desired ETC idle airflow. Is this correct?
2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
Gettin' the Groceries
Yes, that should be the case.
Thanks. Just want to be sure that I am actually doing something other than just amusing the PCM when I modify the corresponding tables and log these PIDs.
