Results 11 to 20 of 24
Thread: November 14, 2006 v7.3.3 is now available.
  1. #11
    Is this download above the TNT and DSP5, etc. or is it just an update for the Vin# probs?
  2. #12
    Feb 2006
    If you have a FlashScan V2, please make sure you are running firmware V2.4.38 or later. It contains an important fix to prevent PCM reads from hanging or failing prematurely. You can check the firmware version in your FlashScan V2 device using the menu sequence: F4->F1->F1, then scroll down to the Firmware version display. If your FlashScan V2 is using an earlier version, please reflash it with the firmware (*.ffw file) contained in the zip file.
    I need to do this to mine, but I'm probably being a little dense and am missing the button marked "push me to reflash" - I've got the ffw file, how do I reflash the V2?
    Cheers
    Jim
  3. #13
    Feb 2006
    OK, found it and re-flashed successfully.
    Jim
  4. #14
    Quote Originally Posted by 05lly2500hd
    It does not contain TNT or DSP5.
  5. #15
    Dec 2005
    any ideas when DSP5 will be out
  6. #16
    Member Treurentner's Avatar
    Nov 2005
    Talking
    Hi Paul,
    great soft,
    found that the old foodpound to newtonmeter (GM.TRQENG) pid bug was solved
    And now we have the real BIG numbers...
    Btw this car was dynoed with 706 Nm /4679 rpm)at the crank (so the PCM calculations are ony 5% off), after that too much wheel spin for the right max Hp numbers, should be close to 500 at the wheel.
    Good work, I hope that I can order the V2 hardware soon (still collecting money)
    Best regards from all af our Corvette-clubmember here in Germany.
    Marco
Name:	Tina C5 1997 max torque.jpg
  7. #17
    Oct 2003
    Default Separate (.ffw file) for V2 firmware upgrade
    Would it be possible to get the .ffw file broken out separate from the 7.3.3 file. I have a dialup connection and it is to much to down load that whole file.
    Thanks, Jim
  8. #18
    Oct 2004
    The firmware file is tiny to be honest.... Would make a difference of perhaps 3 seconds on download.
    Edit: If you just want the firmware file (and not the 7.3.3 release) then I can host it temporarily.
    Andrew
    EFILive Crew
  9. #19
    Attached.
  10. #20
    Oct 2003
    I have v7.3.2 installed. I use it on my 01 Z06.
    Are there new tables in v7.3.3, versus v7.3.2, that would apply to LS1/LS6???
    TIA.
    joel
  1. 2006 MAX no PE ?
    By fastjim455 in forum Gen III V8 Specific
    Last Post: January 8th, 2009, 05:59 PM
  2. COS for 2006 OS
    By MoTruck in forum Custom Operating Systems
    Last Post: July 9th, 2007, 02:07 PM
  3. Replies: 0
    Last Post: October 29th, 2005, 03:22 AM
