Results 1 to 3 of 3
Thread: Need help setting WOT 1-2 shift
    Nov 2006
    Default Need help setting WOT 1-2 shift
    I added a Trans Go shift kit to my car, now it short shifts on the 1-2 shift at 5700 RPM @ 39MPH. It is programmed to shift at 36mph & 6000 on the 1-2. It is exceeding the MPH, but not reaching the RPM? The 2-3 shift is fine. Should I start changing the RPM or the MPH to dial in the shift?
    12secformula,
    Welcome to the forum.
    You could try either of these:
    a. raise the RPM a few 100 and see if it shifts higher, or...
    b. raise the MPH a few and see if it shifts higher;
    Joe
    Nov 2006
    Thanks for the info and the warm welcome! I set the upshift at 39MPH and it shifts right where I want it to.
  1. Setting an LBZ to defuel during shift?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 25th, 2009, 06:31 AM
  2. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  3. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  4. fan setting for ls2?
    By minytrker in forum Gen IV V8 Specific
    Last Post: June 15th, 2007, 03:45 AM
