Results 1 to 8 of 8
Thread: Maybe i'm missing something but... (V2)
    Aug 2005
    Default Maybe i'm missing something but... (V2)
    How do you get the transmission file out to look/alter it on these new cars (using V2)?
    I'm trying to get the transmission file out of my mom's 06' Monte Carlo SS.
    Also, has anyone had weird readings while logging? I logged my mom's car and all the fuel related stuff was going crazy on the log (LTFT's, AFR, duty cycle..etc) but its fine with my car.. (V2) I was seeing like 300% duty cycle down to 0 and back, +80% LTFT's, really high AFR all fluctuating up and down all over the place.
    1992 Turbo LSX Notchback Mustang 275 radial car - under construction
    2008 Sierra 2500HD Duramax
    Jan 2005
    First of all, stop messing with your mom's car. After all she's done for you, you want to go and turn her vehicle into a hot rod?
    What you're seeing when logging is pretty typical when you use LS1 PIDs on an LS2-based system. You need different PIDs for CAN based systems (LS2) than you do for VPW (LS1). I've set up two different dashboards and PID files for each type of vehicle to make switching back and forth easier.
    When you want to read the transmission controller, you have to select TCM instead of ECM or PCM prior to initiating the read.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Also, goto File->Enter VIN and enter the correct OS id and transmission (auto/man).
    Quote Originally Posted by Chris81
    The T42 transmission calibration support is currently being tested and will be released in the next week or two.
    Aug 2005
    Sweet, thanks for the help guys!
    I figured it was something small I was missing.
    Aug 2005
    So, what selection of PIDs do I need for LS2ish stuff? I'm not seeing anything different to change as far as PID selection..
    Jan 2005
    There are a few subtle changes. Depending on what you're logging, you'll need to look for PIDs that report rational data. SAE.MAF, GM.AFR_B, GM.AIRPERSPEC are some of the PIDs that are compatible with LS2-based systems.
    678/344-1590
    Aug 2005
    Ok cool, thanks again..
    I'll start trying them out.
  1. Another missing PID
    By gmh308 in forum Black Box Logging
    Last Post: September 29th, 2009, 12:00 PM
  2. Missing VIN
    By 99STEPSIDE in forum FlashScan V2
    Last Post: February 11th, 2009, 02:30 PM
  3. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 02:28 PM
  4. PID's Missing or am I missing something
    By dperry in forum Duramax LLY
    Last Post: March 1st, 2007, 02:15 PM
