Results 1 to 6 of 6
Thread: 7.3.3 bug ?
    Oct 2006
    Default 7.3.3 bug ?
    Downloaded 7.3.3 , after downloading I removed V7.3.2 and reinstalled with 7.3.3 (yes backed up .tun and .efi files) , everything looks ok except when I click on the rotate 3D model it spins around several times very quickly more than 90 degrees and stops at something like 270 degrees , not a big deal can rotate with just right clicking and holding down the button while rotating with the mouse pointer , but none the less it does act weird , bug or what ?
    2006 Trailblazer
    x2^
    Yup, its a bug - well sort of.
    I was generating 3D rotating images for "sales and marketing" and it looks like I have accidentally left in the code in that saves the frame-by-frame images of the 3D rotation.
    The 60 frames are saved as *.bmp files in the \Program Files\EFILive\V7\ folder.
    You can delete those files at any time - or convert them into an animated gif which is what I was doing. See image attached.
    It wil be removed in the next update and the correct functionality of that button will be restored.
    (Thanks for finding it - it had slipped passed testing un-noticed).
    Oct 2006
    No problem , that will be $300.00 , .
    I just want to be able to access my wife's 06 Trailblazer .
    2006 Trailblazer
    You should be able to get into that 06 LL8 PCM by now with V2 I think... I know the TB SS guys are happy they can finally get EFILive for tuning their rides.
    Oct 2006
    Quote Originally Posted by ScarabEpic22
    I was told by Wait4me before I bought the V1 that it would do it with just a software update (7.x.x to 7.x.x) , I posted to that fact and asked why I was not able to access my 06 Blazer after I did a software update .
    I would have just waited , I mean for couple hundred more I could of had the V2 , but still be waiting for software to use it as well .
    2006 Trailblazer
