Well, we took my buddies truck out tonight and was scanning/logging some data trying to get it dialed in. The fuel trims were around +15-+25. So I added a little to the VE table, disabled the LTFT's, DFCO, and MAF, and Logged some STFT's, after 2 good logs and tweaking on the VE table I got the STFT's around +-5% across the table pretty much. So I figured I could re-enable everything and check out the LTFT's now since the VE table was off pretty good in some spots (as much as 20%in some areas). Well the LTFT's wandered back up to about the same spot as earlier! I scrolled over and checked the DTC's and there was a MAF Sensor Performance code (P0101 I believe). Do you guys think that is what is jacking the fuel trims up like that or do I just need to spend more time on the VE table?
