Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: Stock GEN IV Files
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Thumbs up Stock GEN IV Files
    If you guys would, please send your stock GEN IV files as well as a description to either Tordne or myself so they can be added to the list.
    www.holdencrazy.com
    Oct 2003
    Default Support for 06-C6 with V2
    Does anybody know if the 06-C6-LS2 is currently supported with V2?
    Thanks, Jim
    Jan 2004
    It depends on what controller is in the vehicle. If you want to post your vin I would be happy to check it out for you.
    Oct 2003
    Thanks for the reply Black 02SS. I don't know the Vin of the car as I have not seen it yet. So does the 06 model year C6 LS2 use both the E-40 and E-38 Controller? This is an LS2 not LS7.
    Thanks, Jim
    Default 2006 Corvette E38 and other ECM application info
    All 2006 model year Corvettes (Z06 or base car with the LS2) use the E38 so if your VIN has a 6 in the 10th digit (or a 7 for the 2007 cars), the current release of EFILive will not reprogram them. The 2005 Corvette uses the E40. It was not a mid year model change. The 2005 Corvette uses a different crankshaft reluctor (24x wheel versus 58x wheel on the 2006-2007). You can not mix the engines and controllers/software. The 2006 engine won't run in a 2005 Corvette and the 2005 won't run in a 2006 Corvette.
    To confuse things a bit, the 2006 LS2 in the Trailblazer SS, SSR and GTO still has the 24x crankshaft reluctor wheel (and the 2x cam sensor wheel versus the 4x wheel on the newer engines). These vehicles (2006 Trailblazer SS, SSR and GTO) use the E40 ECM like the 2005 Corvette did. EFIlive should support these vehicles because they use the E40 computer.
    The crankshaft speed sensors are different for the two different reluctors and they are color coded so you can also tell by the color if it is a 58x sensor or a 24x sensor.
    Jason
    Apr 2005
    Default 05 LS2 Support
    Can you please tell me if the following LS2 controller is supported?
    VIN
    1G1YY24U955100573
    Thanks....
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    I've sent a copy of a stock 2007 LS2 MZ6 Corvette but I don't see it on the list. Did you NOT get it?
    I also tried to attach it to this post and it doesn't show.
    Would ya'll mind increasing the size of the "tun" files in here as attachments? My 1 meg file won't fit from my 2007 Corvette tune.
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Apr 2005
    Elemer
    No I did'nt get it.
    Could you please send a copy to robrizok@aol.com
    Completely stock, yes?
    Thanks in advance
    Bob
    Apr 2004
    Quote Originally Posted by Black02SS
    www.holdencrazy.com
    Tordne has his e-mail turned off in his profile.
    I transmitted to you and I used tordne@holdencrazy.com that for tordne. I hope one of you gets the file. Let me know.
    Elmer
    Oct 2004
    Got it thanks mate
    I've forwarded it on as it is an E38/E67 unrecognized PCM which we need to produce a cal for.
    Andrew
    EFILive Crew
  1. Stock LS3 tune and trans files..
    By Chris81 in forum Gen IV V8 Specific
    Last Post: April 20th, 2008, 11:57 AM
  2. EFILive Stock *.tun Files!!! In Here!!!
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2008, 06:45 AM
  3. E38 stock files needed
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: February 10th, 2008, 03:42 PM
  4. Stock tuning files, All years please!
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 17th, 2007, 05:48 AM
