Oops, I forgot to send the files to Tordne. Sorry for the delay.
I just sent them to him to be added to Holden Crazy.
02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
15 C7 Z5 1 Coupe - stock for now
12 Avalanche - tune, Corsa Touring
We did a LS3. EFIlive does not recognize this LS9 auto Camaro.
Thanks.
Alex
That calibration you sent via email is supported with the latest pre-release version 7.5.6 Build 107 available here (http://forum.efilive.com/showthread.php?t=13140).
Also download the 8.1.2. Build 87 release and update firmware to 2.06.28. Also get the ZIP file in post # & of that thread and extract to the location shown in that post.
Andrew
EFILive Crew
Yes get the zip file from post #7: http://forum.efilive.com/showpost.ph...40&postcount=7
Thanks guys, it worked!
can you tell me if this controller is supported. 2006 C6 Auto trans vin#********
I can advise that the E38 T43 controllers used by that VIN (which I've removed) are supported by FlashScan V2 Scan and Tune.
Andrew
EFILive Crew
bfabiano,Originally Posted by Blacky
EFILive supports the vehicle you enquired about (VIN provided by you).
However, you may have to upgrade to a supported OS... the latest one is 12614682.
Goto http://tis2web.service.gm.com/tis2web and enter your VIN, select PCM/VCM and click Next...
you will see what the dealer will upgrade your OS/calibrations to (the latest one is at the top, 12614682).
