Ok, I just got done rifling through a stock 05 C6 bin. While snooping through the idle parameters I don't see where you set the desired idle speed. I see a max idle speed, where is the base idle set?
Can we assume that the desired air flow table (GEN3) is now the minimum idle airflow table? Why is GM now stretching this table through all gears and rpm ranges. Is this there way of blending the throttle cracker/throttle follower in one parameter?
Howard
