I posted this over at DP, and figured I'd post it here to. Maybe a few different eyes here can give their input as well...
This thing is SWEET! The licensng had me freaked for a minute... Does 7.3.3/V2 read the ECM/TCM Serials differently than 7.3.2/V1? On the V1 cable it list the TCM as TCMXXXXXXXXX and the ECM as M04XXXXXXXXX. on the V2 it's listed as what I guess is the last 9 of the module's S/N (No TCM or M04). BUT... If I read the TCM info (Flash/Show PCM Info) the last 7 are 0's, and the first 4 match PART of the S/N in both cables, but there's an M at the end where there was/should be a 5. Similar with the ECM, the first four of the read info match part of the Licensed S/N, but there's an M where there was/should be a 0. Any ideas Ross or Paul?
On a somewhat unrelated note, any ideas why it doesn't seem to be flashing my VIN into the TCM? If I read my original TCM, I get the VIN, but on the EFI one, after I did a cal flash, it no longer has the VIN .
Any chance of getting a "Intiate Fast Learn" for the TCM in these at some point? (I know the software can't even do it; it would be nice to be able to just initiate FL but not clear TAPS).
