Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Cylinder Select?
  1. #21
    I read that Crane Cams and Comp Cams can custom grind you a small block chevy cam with alternate firing order (so all you have to do is change the order of the spark plug wires on the distibutor); the reason you may want this "marine" firing order is that some people say it has better "intake balance and/or exhaust header balance (...something about 2 adjacent cylinders firing in sequence messes up tuned header design)", and "promotes better cooling".
    So... thinking out loud, I'm wondering if it's possible to change the firing order in the LS1/LS6 PCM and get a alternate firing order cam ground...?
    You could casually drop "...oh yeaarh, I changed my firing order..." in your converstions... he he he.
  2. #22
    Yeah, just swap the wires!!, (I'm not kidding here!!).
    As far as the PCM is concerned, it is just firing outputs A - H, how they are hooked onto the engine is upto the engineers.
    Imagine running an old 455 Pontiac on an LS1 PCM
  3. #23
    Yah got me thinking Ross , We converted the shop 68 Firebird to Delco injection and stroked it to from a 400 to a 462 a few years back , may be time to upgrade the PCM and chuck a 4l80e into it - nah darn site easier to chuck a spare LS1 and a blower onto it than to do the conversion.
  4. #24
    Mar 2005
    Spare LS1 and blower Delco? What are you running in the Monaro now then?
    And if the blower is spare send it up my way. I have a pesky silver clubbie to beat which means I need to drop from 13.0 to 12.7 somehow.
  5. #25
    Quote Originally Posted by jsttry
    I have a few spare LS1's laying around , no blowers though at present I sold my 2.4l whipple and are still awaiting the 3.3l whipple to turn up.
    Monaro at present is running a the same bottom end as always - a 383ci 224 cammed daily driver The 3.3l should liven it up a little
  6. #26
    Ross, mate, you're pure genius...
  7. #27
    And you'd have to swap the injector wires also too, eh.
    455 = big cubes -> big torque
    455 + PCM = bigger and wider torque
    (I wonder how big torque will be below 2000 RPM...? )
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 02:34 PM
  2. What PIDS should I select?
    By LM7Tuner in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2009, 07:33 AM
  3. Can't select RAFIG PID's in either BBL or Scan tool!
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 01:53 PM
  4. cant select pids ini not found error message
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: September 3rd, 2008, 11:02 AM
