Results 1 to 10 of 14
Thread: Show off your timing...
    Jun 2005
    Default Show off your timing...
    Just for kicks, post up your powertrain mods along with the stock timing table, current timing table, and maybe an explanation why you made the changes. Thought it might become a useful thread to those who don't know so much about timing...
    2002 Z28 (A4)
    SSRA, SLP lid, Pacesetters, ORYP, and Magnaflow
    I made the following changes after comparing my stock file with a Corvette (A4) file. The C5 had quite a bit more timing in the low-mid range. A little smoothing was done to the light load areas. WOT was set to command the same values as the stock file would command different timing under WOT with a slight change in grams/cylinder. Now running 24*@6000RPM under WOT.
    Stock Timing.......Current Timing
ID:	1086   Click image for larger version.
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Mods are in the sig. Spark was derived from lot's of time behind the wheel and dyno. Best power was made at 28* at 80F IAT temp.
    Senior Member lakingslayer's Avatar
    Dec 2005
    I know this is the gasser section but I thought I'd share my timing on my Duramax. GM has the timing adjusted for emissions at the cost of power and economy. Plus my injector pulse times went from example 1476usec to 3300usec. [IMG]c:%5C[/IMG]
    Stock timing ........ My Timing
Name:	stock timing.JPG
ID:	1090   Click image for larger version.
Name:	modified timing.JPG
    Lifetime Member Rhino79's Avatar
    Jul 2006
    How do I get the table from the tune? I can't seem to find out how to get the image.
    Jun 2005
    Ctrl+PrtSc (Print Screen)
    Then, you can paste it in MSPaint, size it down and save as a .jpg.
    Jul 2006
    Here's one of a 408, 10:1 compression, 233/239 113lsa cam, pacesetter's, no cats, 3" dual exhaust thru 12" bullets, stock truck intake and tb, full bolt-ons. This is in a reg cab 2wd truck, it seems to like 27* at WOT the best.
    Mar 2005
    For those on 95 OCtane in New Zealand :( boo-hoo
    under full load at 1800rpm I start on 16degrees, by 3600rpm I'm at 24 to 26 degrees, dropping out to 18degrees at 4800rpm and increasing to 22 degrees at 6200rpm. Will post an example later.
    Mike
    Junior Member 70LS_Nova's Avatar
    Nov 2006
    Default table
    Comp XR275HR
    Not dyno tuned yet... but runs awesome!!
    1970 Nova - 2001 Z28 LS1 A4
    Comp XR275HR, Longtubes, Ported/Polished 241's
    EFILive V2!!
    Oct 2003
    LS6 bottom end
    LPE/GMPP LS6 heads
    239/251, 106 lsa cam
    90 mm Fast Intake 90 mm NW TB
    Kooks 1 7/8 header
Name:	High Octane Timing  Non Stock.JPG
ID:	1103 Click image for larger version.
Name:	High Octane Timing Stock.JPG
    Feb 2007
    OK, to what extent is smoother better?
    2004 Pontiac GTO - Quicksilver/red/m6
    1-of-344
  1. Show me your A0014's
    By vetteboy2k in forum Custom Operating Systems
    Last Post: November 26th, 2012, 01:26 AM
  2. how much max, NA, WOT air flow (g/s) does your log show?
    By LS1-450 in forum Gen III V8 Specific
    Last Post: June 20th, 2008, 03:13 AM
  3. Vin # in tune does not show the same as my vin...
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 10:04 AM
