Results 1 to 8 of 8
Thread: Which WBO2 would work the best for......
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Default Which WBO2 would work the best for......
    So what do you guys think would work the best for moving from vehicle to vehicle frequently? I know that EFILive is already set up for the LC-1, LM-1, PLX, and a few others, but I have heard good things about the AEM setup that has the controller in the display and it is supposed to be very portable. Is there a way to set up that WBO2 where I can use it like LC-1 for my BEN?
    Jan 2005
    you just have to know what the output from the WB controller looks like. From there, you're just a custom PID away.
    That being said, I think the LC-1 could be made portable fairly easy.
    Jul 2004
    The only things you need to make a wideband portable is a cigarette lighter plug or some other easy way to get power, a dedicated plug on the analog output so you can easily connect and disconnect from your EFILive cable and a big wrench so you can take the sensor in and out easily. It helps to be able to easily unplug the sensor so you don't twist the cable when taking it in and out. And if you're willing an exhaust pipe clamp like the one Innovate sells makes it even easier but it does make the readings less accurate, especially at idle.
    Ira
    Jun 2005
    LM-1....no doubt.
    Jan 2004
    Another vote here for LM1. I have used mine COUNTELSS times in and out of cars without fail. Very durable and a great unit.
    Jan 2006
    Add 1 more for the LM1. Use mine almost everyday in and out of cars without a problem.
    Feb 2005
    if I was going portable I would think LM-1. If you want stealth. I say go LC-1 you can easily hide that bugger. or completely integrate it, like so:
    2004 Pontiac GTO Torrid Red on Red M6
    CAI Inc. CAI|CAGS Tune Elim.|3.91 Gears|Harrop Diff. Cover|SLP Sway Bar|04 SAP|AMW Catch Can|Raptor Shift Light|Nitto 555DR's|Kooks 1-7/8 LT's HPC Coated|Dual Innovate LC-1 Widebands |TexClutch | GMM Ripshift |Hurst Line Lock|
    Oct 2005
    LM-1 gets my vote. The display is great and it's a pretty tough unit.
  1. How do you log WBO2 lambda instead of AFR?
    By waveoff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 08:03 AM
  2. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  3. Installing wbo2
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2008, 11:20 AM
  4. WBO2 controller
    By Thumper in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2008, 12:53 PM
  5. wbo2 opinions
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2007, 04:16 AM
