Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Thanks to the EFI Live crew and a couple of questions
  1. #11
    Lifetime Member mistermike's Avatar
    Dec 2003
    Thanks again. The concept of a firmware controlled unit makes a lot of sense, and will certainly give the product good "legs" and a much longer hardware obsolescence cycle. I'm grateful for the old addage that "good thinking costs no more than bad thinking." Othewise I wouldn't be able to afford it!
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
  2. #12
    Lifetime Member johnv's Avatar
    Jan 2005
    Just to clarify , once vins are transfered from V1 to V2 , will I still be able to use V1 on those PCM's ? (as a back up)
    or only V2 !
  3. #13
    Sep 2005
    All licenses on V1 will still do everything they did before, you just won't be able to add any new ones after you upgrade and copy (a better word) vins to V2 .
  4. #14
    Jan 2005
    Cool and if you had unused licences on V1 that you did not transfer, they would still be able to be used on V1 , right.
  5. #15
    Jan 2005
    I believe so
  6. #16
    Lifetime Member Garry's Avatar
    Jun 2006
    Quote Originally Posted by kbracing96
    So, I got my V1 cable here, with one PCM license used - new V2 should show up soon I recon (Richard?) with two PCM licenses unused - so the one V1 PCM license could get transfered, still keeping the two PCM licences free?
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
  7. #17
    Sep 2005
    Yep!, but you can only use the license transfer tool once, so if you have any other unused licenses on you V1 you need to choose whether to leave them (which you can still use them) on your V1, or transfer them to your V2 when you copy your used licenses to the V2.
  8. #18
    Jun 2006
    So, if I transfer my PCM ID over, and the unused PCM license is left (and eventually used), can additional licenses still be installed on the V1 cable?
  9. #19
    Sep 2005
    Quote Originally Posted by Garry
    Nope, once you use the transfer program, no more licenses can be added to the cable. In fact, you would have to check with Paul on this, but I believe once you use the serial number from a V1 to upgrade V1 to V2, I don't believe they will let you add licenses to that V1 either way. You would have to out right buy a V2 to still be able to add licenses to your V1. That's why the upgrade is cheaper. There just letting you keep the V1 as a spare tool since it would do them no good to have a bunch of old V1 sitting in the corner.
  1. High Marks to EFI Live Crew
    By acomp917 in forum Lounge
    Last Post: February 17th, 2010, 10:09 AM
  2. Couple of LMM Questions
    By Cougar281 in forum Diesel
    Last Post: January 26th, 2009, 06:42 PM
  3. couple of questions ...
    By drdarthinvader in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 4th, 2008, 02:33 AM
  4. Couple little questions
    By samdweezel05 in forum Duramax LB7
    Last Post: November 22nd, 2008, 05:25 AM
  5. couple of questions.....
    By WHYTRYZ06 in forum Custom Operating Systems
    Last Post: March 16th, 2008, 05:37 AM
