Results 1 to 8 of 8
Thread: Idle Tuning
    Jul 2005
    Default Idle Tuning
    What AFR are you guys trying to tune to for idle at normal ops temp 14.63 or something leaner?
    I have a Map logging IACDES_B by ECT, but all the readings log in PARK/NEUTRAL and I have a MN6 but my Desired Air Flow by ECT has both In Gear and Park/Neutral columns with all the data in the In Gear column.
    Is something wrong here?
    Lonnie
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Junior Member MCG's Avatar
    Jul 2005
    9.12:1 A/F
    Oh, but mines on alcohol
    Jan 2004
    Depending on the car anywhere from 13.8 to 15.0
    Oct 2005
    Quote Originally Posted by MCG
    9.12:1 A/F
    You should join the alcoholics anonymous forum!
    Oct 2005
    Just to add something here and please correct me if I'm wrong. The best idle you will get is when you're making the most vacuum. To optimize your idlle, the combination of timing and afr will be such that you make the most vacuum. Make sure to scan your vacuum as you adjust your timing and afr and look for the point at which you make the most vacuum. Now, you do have to be careful because although adding more timing may smooth out your idle it will also cause your car to surge. Add timing slowly and once you reach the point where your vacuum reading no longer changes stop. You may even want to back off the timing a degree or to at that point to see if it makes any difference. Before making changes, always give the engine a chance to stabilize itself. As has been stated, use the bidirectional controls in the scan tool.
    Oct 2005
    Highest vacuum and leanest is what I understand. "lean best idle" on google will throw a few hits.
    2014 VF SV LS3 Maloo.
  1. E38 idle tuning
    By hymey in forum E37, E38 & E67 PFI ECM's
    Last Post: August 3rd, 2020, 10:53 PM
  2. Idle/Idle Transition Tuning
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 11th, 2007, 04:10 AM
  3. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 02:58 PM
  4. Idle Tuning
    By 98WhiteDevil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 03:36 AM
  5. tuning idle
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 08:07 AM
