Results 1 to 9 of 9
Thread: Bottom line V1 vs V2...
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Question Bottom line V1 vs V2...
    Since I have the LS6 and my son has the LS1 and I do the tune work on both engines, I really have no need to go to the V2, correct? Were I to buy a car that has the LS2 or a Gen IV engine, then I would need the V2 to be able to do what I do now. Is that correct?
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    What you can achive with a LS1/6 is not different between a V1C and a V2 IMHO. It may become more convenient with a V2 but the availble scanning and tuning perameters seem to be the same. Granted, my experience with V2 is limited compared to V1.
    PowrMax Performance
    100 mm PowrMAF
    Apr 2004
    Sooooo I can tune a Gen IV with the setup that I currently have BUT I require my laptop whereas the V2 would give me the handy dandy portable hand-held box to use in lieu of the laptop. I could then use the stored information in the V2 to view the data on my laptop or desktop? Closer?
    Oct 2003
    You can't talk to CAN bus LS2/7 etc vehicles with a V1 but it is possible to retrofit your LS1/6 vehicle with a LS2/7 (assuming 24x crank reluctor) and tune it with V1.
    Next for V2 is stand alone scanning and flashing which is in the convenience category as I see it. The screen on the V2 is a small 4 line which will never replace the laptop so the V2 remains an interface device for serious, real time scanning.
    PowrMax Performance
    100 mm PowrMAF
    Apr 2004
    Got it.
    Thanks,
    Elmer
    Jun 2006
    Plus the extended duration blackbox scanning in V2 if I understood the specs correctly ...
    And V1 support will drop off sooner than V2. Personally, I'd get the V2 and be virtually future proof, plus have all the standalone functionality.. It'll sure be nice to be able to make tunes in the basement, then oly take the V2out to try them instead of the whole computer...
    Apr 2004
    Well, it looks like $399 to upgrade and I'm not sure I need to upgrade. I went to the "Commercial" level on 9/16 and I'm not seeing the need to keep spending money to do the amount of tuning that I do.
    Elmer
    Jan 2005
    That's the cool part Elmer - You can upgrade when ever you want at no penalty. Took me almost 2 years to out-grow V1, and even then all I needed was an additional 0-5vdc input. BUT, since I've been thru 1 mother board and 3 hard drive's, the standalone features of V2 justified the upgrade cost.
  1. Replies: 2
    Last Post: April 1st, 2009, 12:58 PM
  2. 4.8 that needs serious help off the line
    By chevyman08 in forum Gen III V8 Specific
    Last Post: June 23rd, 2008, 12:35 PM
  3. PE tuning..lean on the bottom..
    Last Post: April 22nd, 2006, 02:37 PM
