I'm getting ready to install my LC-1 this weekend and I have a few questions.
1) Where is a good place to get a switched 12V power source? I was going to use the power wire from the ASR, but I already tapped into that for my halo's. Would I have any problems if I used that same wire for my LC-1?
2) Where is the best place to run the signal and system ground wires to?
3) On the wideband gauge instructions, it says the following: "NOTE: DO NOT RUN ANY GAUGE OR CONTROLLER WIRES NEAR IGNITION WIRES!" Can anyone explain to me why you shouldn't do that? Would I be fine if I ran the wires from my wideband gauge located in A-Pillar, down the side of the dash, under the drivers side kick panel and into the center console?
