Results 1 to 3 of 3
Thread: 8.1L Throttle Surge
    Oct 2006
    Default 8.1L Throttle Surge
    I have been doing some basic tuning on a 8.1L with the Allison. I have only worked on the the PCM side. Basically, I played with the timing and burst knock. I also tried to eliminate torque management. However, now, shortly after it shifts gears, I get a throttle surge like the area circled in the attached log. Basically, something is giving it a quick burst of throttle. Any ideas on what would give it such a burst? It runs well accept for an occacional throttle burst. Thanks, Dallas
    1999 GMC Jimmy 4.3
    Oct 2004
    Have you just noticed this start after going from MAF to Speed Density tune?
    If so.. Check the Desired Airflow table B4307 and probably do the idle transition (search for RAFIG) tuning stuff.
    Also perhaps check the Throttle Cracker and Follower settings and decays.
    Andrew
    EFILive Crew
    Oct 2006
    Thanks for the thoughts. I did not ever tune it in speed density. I added a couple of degrees of timing down low, and tried to remove the torque management. Could it be something in torque management? It usually does it immediately after shifts.
    1999 GMC Jimmy 4.3
  1. low speed surge with TPS at 0.4%
    By The Alchemist in forum Gen III V8 Specific
    Last Post: August 22nd, 2007, 05:34 PM
  2. Anyone want to look at my tune? Cam surge...
    By rosey in forum Gen III V8 Specific
    Last Post: August 4th, 2007, 05:10 AM
  3. surge with only a/c
    Last Post: July 8th, 2006, 08:30 PM
  4. Surge at cruise
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: March 25th, 2006, 03:45 PM
