Results 1 to 5 of 5
Thread: Ls2 Scantool Not Tracking
    Apr 2005
    Default Ls2 Scantool Not Tracking
    can you guys help
    i have upgraded my v2 to the latest soft and firm ware, know the scan tool will not track the timing map.i have checked all the pids and they are supported but it will only track the first or last collum of the spark tabel. can you give me any help. also the comarnded AFR is not correct on the dash.
    PS all the pids in the tune section are marked as not supported is this correct or not.
    Linden,
    Make sure the pids shown on the tune map axis's are selected in the scan tool and that they are valid; take a new log with these.
    Sep 2003
    Also make sure the units are right in the scanner.
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Oct 2005
    I think the issue was the SD pid wasnt working. Reconnect MAF and used maf airflow pid and it worked. Not sure why SD pid wasnt working yet.
    2014 VF SV LS3 Maloo.
    Quote Originally Posted by linden
    Use GM.AFR_B on the LS2
    The PIDs will be marked as supported once you connect to a vehicle and run the Validate PIDS option.
    Make sure you are using the latest software, here:
    http://forum.efilive.com/showthread.php?t=3906
    It contains some fixes for the PID validation routines.
  1. tracking multiple maps
    By limited cv8r in forum General
    Last Post: August 13th, 2008, 09:08 PM
  2. Runway highlighting not tracking
    By Redline Motorsports in forum General
    Last Post: June 15th, 2008, 06:14 AM
  3. Cell tracking with the RoadRunner
    By Whippled 496 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 15th, 2008, 03:53 AM
  4. Tuning Tool not tracking MAP properly?
    By gto_in_nc in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2007, 01:32 PM
  5. Tracking maps with scantool
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2007, 03:13 AM
