Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: COS5 shuts the engine down after 3 seconds...help!
    Default COS5 shuts the engine down after 3 seconds...help!
    I'd appreciate any help that you can provide.
    I had Jesse Bubb program a COS5 with tune (attached) to download into a 1999 Pontiac Firebird. I have EFI Live Commercial version.
    When I flashed the complete operating system with tune into the Moates Road Runner, the car will start and idle smoothly for 3 seconds and shut down. It sets a DTC U1000 Class 2 Data Link Instrument Panel Cluster HC.
    If I restart the car it does the same thing....idles smoothly for 3 seconds and shuts off.
    Jan 2005
    Are you attempting to utilize the TPS VE table? If so, you will need to disable it and log the VE PID (don't recal the name off the top of my head), to populate the TPSVE map initially. Make sure you are using the native units when populating the TPSVE map.
    Jan 2005
    The boys did a good job expaining the procedure in this (long) thread http://www.forum.efilive.com/showthread.php?t=2599
    Quote Originally Posted by TAQuickness
    Not using TPSVE.
    The DTC I posted has nothing to do with it also. I just reflashed my maf tune into the RR and it started right up with the same DTC present.
    Aug 2005
    So you're running an SD tune with COS5 then?
    What is the MAF fail limit set at? {C2903} is the parameter for that.
    2hz 18 failures
    Aug 2005
    Set the hz to 1, 1 failure.
    The 18 failures is probably the problem. It'll take quite sometime to hit that... probably 18 starts/stalls.
    Thanks for the tip!
    Quote Originally Posted by dc_justin
    Reset it to 1,1 and it still runs for 3 seconds and shuts down :(
    Aug 2005
    Has the MAF DTC set yet?
    Can you do a compare between that tune and your MAFLess tune that works and see if there is something horribly out of whack?
  1. LOG doesn't get written IF car shuts down first
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: May 6th, 2009, 05:00 AM
  2. Idle hangs for a few seconds when coming to a stop
    By DaddySS in forum Gen III V8 Specific
    Last Post: September 4th, 2007, 07:52 PM
  3. Replies: 2
    Last Post: November 29th, 2006, 12:37 PM
  4. 0 to 100mph in 9 seconds?
    By emarkay in forum Lounge
    Last Post: September 5th, 2006, 03:53 AM
  5. BB Logging keeps shutting off after a few seconds
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2005, 04:19 AM
