Can I load this PCM using EFI LIVE Commercial ?
If I can What should I be looking out for ? PATS , VIN number etc?
Roy 98SSSSSS
If you are just replacing your PCM, just install it, and full flash your last tune into it.
TAQ, this is a blank PCM ... no old OS on it yet most likely ...
Though, building a bench programmer isn't actually that hard if you can get ahold of a socket ...
Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
www.holdencrazy.comOriginally Posted by Garry
The question is more to the point, will an upload even work in the car if the PCM is completely empty ...
I don't see why not. I'd send a PM to wait4me for a definitive answer.
Yes this is blank PCM coming from GM.
TAQ I eagerly await the truth.
Roy 98SSSSSS
Guys,Originally Posted by Garry
the PCM is shipped from GM with the necessary info in it to communicate with the outside world. Hook up EFILive to it just as TA said and do a full flash with your last good tune. This will install the Operating System and your calibrations. Then perform a VAT relink and your good to go.
www.socaldiesel.com
EFILive-DSP5......Switch your Attitude!
EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
EFILive-DSP4......Switch Your Colorado and Canyon Too!
Got it
Thanks for the help and update.
Roy 98SSSSSS
Well it is in and reflashed . After all those scary warning signs . I was about to say fugg it. Now I am happy.
Roy 98SSSSSS
