Results 1 to 3 of 3
Thread: Changing the scaler number in COS5 doesn't change the key on engine off map reading??
    Default Changing the scaler number in COS5 doesn't change the key on engine off map reading??
    I can change the scaler from 94 to 188 and the key on engine off map number stays the same. Why????
    Found the problem. A 2bar map needs sae.map as the pid .....not gm.map...
    Jan 2005
    Glad you found it! I think I'll add this to the FAQ for future reference.
  1. Changing the VIN Number
    By Behold in forum General
    Last Post: January 9th, 2016, 08:48 AM
  2. Tried changing downshift parameters...no change.
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 21st, 2007, 06:10 AM
  3. COS5 shuts the engine down after 3 seconds...help!
    By onfire in forum Custom Operating Systems
    Last Post: December 2nd, 2006, 08:51 AM
  4. Change Engine Oil Light?
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2005, 07:53 AM
  5. Reading PCM with Z06 Door Ajar :S Check Engine
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: March 24th, 2005, 08:05 AM
