Results 1 to 10 of 13
Thread: wideband way off with V2
    Jan 2006
    Default wideband way off with V2
    My lm1 was was about .2volts off with my V1 and now with V2 its reading 1.4 or so volts off. With V2 its showing an afr of around 19-20 at idle vs 15. WHats differnt in V2 vs V1? I have ot tune three cars tomorrow so I have to figured it before then.
    Quote Originally Posted by minytrker
    The V2 has a calibration option and can be calibrated in conjuntion with the LM1. Using the LM1 software, you can configure the LM1 to output a constant voltage. You need to supply two different voltages (say 1V and 4V) to the EFILive calibration process.
    Using the EFILive Scan Tool software, connect to FlashScan V2 and then select the menu option: FlashScan->FlashScan V2 Control Panel... and follow the onscreen instructions for calibrating the 5V A/D inputs.
    Note: you must also be connected to the vehicle (or PCM bench setup) because the 5V A/D inputs require the 12V power feed from the OBDII connector.
    EFILive now ship FlashScan V2 units pre-calibrated. You probably got your V2 before the calibration equipment was in use at EFILive.
    Feb 2005
    seems it could be a goog idea to do the "calibrate" regardless. There can always be slight variations from source to source, would'nt this make up for it a bit ? if not could you explain what the intent of the feature is ?
    EDIT: DA! Nevermind just tell me to read the manual !I'm not proud of this one.
    Jim
    2004 Pontiac GTO Torrid Red on Red M6
    CAI Inc. CAI|CAGS Tune Elim.|3.91 Gears|Harrop Diff. Cover|SLP Sway Bar|04 SAP|AMW Catch Can|Raptor Shift Light|Nitto 555DR's|Kooks 1-7/8 LT's HPC Coated|Dual Innovate LC-1 Widebands |TexClutch | GMM Ripshift |Hurst Line Lock|
    Jan 2006
    So I need to reconfigure my LM1 to put out a constant voltage? I opened up the calibration in efi and clicked it and it made it worse. What numbers should be in the milivolts window? Im really lost now.
    Jan 2005
    Minytrker - It should definately get better
    going from memory:
    Open the V2 control panel (in the scan tool)
    Configure your LM1 to output 1 volt
    In the V2 CP, click the button next to the 1v reference
    Configure your LM1 to output 4 volts
    In the V2 CP, click the button next to the 4v reference
    Then, in the V2 BP, initial the calibration.
    Post up if you're still having trouble
    Jan 2006
    LM1 still not reading right. I cant get it to calibrate right in scan tool. I have to tune a car in an hour, please help asap.
    Jan 2006
    What should my LM 1 be set at? My milivolts in scan tool are reading 3500-4500 at idle.
    Oct 2004
    I guess there are two things:
    1) The LM-1 needs to be setup to output voltages which match the defined PID(s) in the Scan Tool.
    2) You need to have calibrated the V2 so that it reads the voltages output by the LM-1 accurately (as verified by a DMM).
    Andrew
    EFILive Crew
    Jan 2006
    Thanks to Chad (Black02SS) I finally got my V2 calibrated right.
    Jan 2004
    Glad it is all working out now fine for you. Some things just can't be done over email. :lol:
    I will be working on a new tutorial for guys that have a LM1/LC1 on how to properly configure the outputs with V2. It isn't that bad once you do it but more detailed instructions are needed IMO.
  1. wideband?
    By drdarthinvader in forum Purchase and Shipping
    Last Post: September 20th, 2008, 03:26 AM
  2. rr & wideband...
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 5th, 2007, 08:39 PM
  3. fjo wideband
    By articSS in forum External A/D inputs
    Last Post: May 27th, 2007, 09:02 AM
  4. Which wideband O2?
    Last Post: May 4th, 2007, 11:10 AM
  5. PLX Wideband SM-AFR
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2006, 02:46 AM
