Results 1 to 8 of 8
Thread: 120 to 12v converter
    Feb 2006
    Default 120 to 12v converter
    What amp do I need to run my bench top harness? some converters are as little as .5 amp. THANKS
    Jan 2005
    I don't know what the PCM draws, but I picked up a 15amp for $40-$50 a few years ago
    Lifetime Member Garry's Avatar
    Jun 2006
    Do you have an amp meter? I wouldn't expect the PCM alone to draw anywhere near .5Amps@12V ... haven't tried it, though ... my guess is somewhere in the 50-100mA ballpark ...
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Lifetime Member limited cv8r's Avatar
    May 2005
    i've bench flashed using a 12v 3amp power supply, no problems
    You need 12V with at least 1Amp. Make sure it is a regulated power supply.
    Jan 2004
    Check radio shack. They have a regulated 3A with cigarette lighter plug as well a terminal plugs for under 50.
    Feb 2006
    THANKS, for the replies
    Jun 2006
    Is the PCM actually using that much power??? Heck, I'm running a complete quartermile timing system with 18 light barriers etc. on 22V/.580A ... (minus the 220V lights)
  1. converter will not lock under wot
    By camcojb in forum Allison 5 & 6 Speed
    Last Post: April 12th, 2011, 09:49 AM
  2. converter locking in 2nd & 3rd @ WOT
    By Superado in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2009, 08:27 AM
  3. Torque Converter?
    By Bradazz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2007, 01:28 AM
  4. Possible EQ/AFR converter fault in 7.4.2
    Last Post: April 28th, 2007, 09:31 AM
  5. converter lock up
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2006, 03:03 PM
