Results 1 to 10 of 10
Thread: COS5 question on STFT's
    Default COS5 question on STFT's
    After I modified the tune per the EFI Live COS Tutorial, I can't get the STFT's to move off zero when I log. The tutorial says when Closed Loop is Disabled and STFT is disabled, B3647 is dominant and a semi loop state is enabled with o2 feedback through stft's.
    Is there a special pid other than stft bank 1 and 2?
    Jan 2005
    What's your EQ or commanded AFR?
    14.6 in B3647 0 to 90kPa . Also 14.6 in the stoi table.
    Do you have to enable B4108 or B4205? I also have B3801 disabled and B4101 set to 80kph. Just not sure of the mix to get "semi closed-loop".
    Jan 2005
    IIRC, you will need to adjust B4205 back to stock to enable STFT's. You might want to wait for someone else to chime in as I've been !nb for some time now.
    Oct 2004
    B4108 relates to idle so you can enable that if you want...
    Strictly speaking to enter Semi-Open Loop mode you simply need to have the intended cells in the B3647 table set to the same value as B3601. If your tune doesn't have the B3601 table then it is hardcoded to 14.63:1. If you use dsplay units of EQ Ratio then just set the cells to a value of 1.00.
    Andrew
    EFILive Crew
    Quote Originally Posted by Tordne
    B3601 is set to 14.6
    Cells in B3647 is set to 1.0 (In lambda)
    But, STFT's are not logging with B4108,B4205 and B3801 disabled.
    Thanks for the tips, I'll play more tomorrow....this COS5 stuff is addictive.
    To get "semi open loop" on my car:
    B3647 must be 1.0 in all lower cells.(less than 80kPa)
    B4108 must be enabled.
    B4205 must be enabled.
    Keep the LTFT disabled.
    B3601 = 14.6
    Now the STFT's log on FS.
    Quote Originally Posted by 69camaro5speed
    having problem with custom operating system 5 cant get closed semi closed loop to work tryed ever thing i have read here. i have done custom os3 3 other times they all worked i have about 7 tunes i tryed if some one want to look at them
    Post up a tune.
    Lifetime Member Doc's Avatar
    Oct 2005
    I'll look at em'
    www.efialchemy.com
    www.greatamericancarwar.com
    Dec 2005
    nothing like working all weekend on a problem you know you just over looked some thing while wife and kidds are wanting to do some thing.not giving up easy will kill me some day lol
  1. COS5 question for ROSS
    By kbracing96 in forum Custom Operating Systems
    Last Post: August 24th, 2011, 10:18 AM
  2. Help COS5 Semi OL STFT ?
    By RandyWS6 in forum Custom Operating Systems
    Last Post: August 22nd, 2008, 02:13 AM
  3. COS5 With A 2 Bar Map Sensor Question
    By ForcefeedWS6 in forum Custom Operating Systems
    Last Post: August 23rd, 2007, 09:39 AM
  4. COS5 Question????
    By BowlingSS in forum Custom Operating Systems
    Last Post: August 20th, 2006, 02:59 AM
  5. Replies: 8
    Last Post: July 19th, 2006, 02:36 AM
