I would like to know this also.Originally Posted by VortechC5
Thanks,
Bill
Thanks,
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System;
Tinted Windows 35%;EFILive Tune
AutoTune will only work in SD mode (mafless).
As Ross has stated at the start of the this topic, The best place for the Maf is in the bin. :wink:
Shouldn't this thread be a "sticky"?
Has anyone successfully run MAFLESS (SD) with a fly-by-wire throttle ??
joel
Agree and yes.Originally Posted by bink
2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
Flashing control modules since 2001. 8-)
Who needs a MAP sensor on a supercharged LS6 anyway.
Thank you.Originally Posted by SinisterSS
Sticky??? Blacky, GMPX?
maybe I missed it somewhere, but is this remotely possible without a WB, can i work off the narrows or not?
Thanks for the Sticky!
joel
I had to go with the competition to tune my 98 a few months back due to no support yet from eflive :( was a bummer, but gotta do what ya gotta do.
I do still have my trusty efilive cable sitting in my laptop bag.
can I work this auto ve and maf magic with just efilive V7 and then export results to hand enter into my "other" tuning product????
Heath
98 Formula
Half-Assed Racing Custom STS kit in progress.
There are a couple of key things that are needed to do the Auto Tune, from my perspective.
1) You need to be MAFless - running in Speed Density mode
2) You need to have a Wide Band O2 sensor - basically so that you can compare commanded vs. actual AFR's
3) I'm sure this is dumbed down, but basically what the Auto Tune process is doing is looking at the commanded vs. actual AFR's and calculating the difference (factor) between the two. So that, for example, in cell 4000RPM x 55kPa your factor could be 1.10, which would mean that you are over fuelling by 10% at that specific point.
In EFILive there is a MAP that calculates all these factors for you, and allows you to paste back into the tuning tool using these factors to correct your VE table. Prior to this being available within the EFILive product it was being done in Excel Spreadsheets, so ultimately you still have that option available irrespective of the tuning tool you use.
All you would need to be able to do is build two tables, one for commanded AFR's and one for actual. Then compare the two to see how far out your actual AFR's are.
Hope that makes some sense, or if I am wrong, please flame me...
Hopefully you will have your 98 support soon anyway... Paul and Ross are working hard on this as we speak!
Andrew
EFILive Crew
