Just two to start with.
One for the Aussies to replace 12225074.
One for the 2002 F&Y bodies to replace 12212156
If you are already running a custom O.S based on one of those O.S's then all existing tunes are compatible.
Same process as the others, Full flash the O.S #5 tune in, then flash the cals only from the existing tune you are running, then read it out and save as your new O.S #5 file and adjust the new tables / parameters.
Setup suggestions.
A0003 - Set to disable for now until the tutorial is done (or you are feeling brave).
N20 monitor is done via the same input as the Valet mode, once it is grounded then the two compensation tables become active, although, there is two parameters to stop those two tables even if the N20 is on.
Good luck, let us all know how you go.
Download here -
http://efidownload.iqd.co.nz/softwar...5_OS_Final.zip
