Results 1 to 10 of 11
Thread: Idle/Idle Transition Tuning
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Default Idle/Idle Transition Tuning
    Well first off, Thanks Black02SS (Chad) for poining me in the right direction earlier today. I have been battling rpm "hunting" problems for a while on a buddies truck now for a while, a 408 Silverado. I have been searching around a lot on here and found tons of helpful advice an tuning various things like idle timing, Learned Airflow tables, Desired Airlow, etc. and monitoring the correct pids. What Chad showed me today though took me 180 degrees from where I was goin with the tune. The truck started right up, idled great, all was well until you would start slowing down and then the surging and bucking would progressivly get worse till at a complete stop. As it turns out, all it too was a little more desired airflow and changing the Throttle cracker activate/deactivate speed and just like that its all good. Thanks again for the help and I hope my experience will be valuable to someone in the future!
    Senior Member ArKay99's Avatar
    Apr 2004
    Can I ask what the change to the cracker activate/deactivate speed was? I'm having simialr issues, not bad at all, but I feel I am close and just need a tweak.
    Go:LPE 403, VaraRam, Haltech, PowerMax 100mm MAF, Tony Mamo ported FAST90/NW90, 160* stat, Kooks, TI's, DRM cutouts, Ripper, 4:10's, Tex OZ700, QA1's, Tony Mamo ported AFR 205's, 242/242 .610/.610 114LSA+2, Yella Terras, 42lb/hr Green tops, ASP UD pulley, 2 AMW catch cans
    Show: Euro tails & mrkrs, Z06 chromes/Pilots, 300Wx2 Bolt w/12" Sub,
    red calipers & black rear letters, Zaino.
    530 RWHP, 479 RWTQ
    Jan 2005
    I've been tuning my cracker tables lately as well. For grins, I raised my activate speed to 20mph, and left the deactivate stock.
    This enables me to compare the difference in driving characteristics with the cracker both active and inactive. In my case, and it's probably a rare case, having the cracker inactive made low speed drivability worse.
    If deactivating the cracker does not help you, then you may need to identify the bucking area of your cracker table, then make small <5% changes up and/or down until you find the sweet spot. Incorrect values in the cracker table, especially at low load/rpm, can have a big effect on low speed drivability.
    Jul 2006
    Quote Originally Posted by ArKay99
    Well I started at 10 enable and 9 disable, then when it would disable it was fine but from 15-10 on decel it would hunt some, so I raised it to 18 enable and 17 disable.......problem solved! For me anyways!
    Apr 2004
    TAQuickness, thanks, I'll try that tonight, was out of town for 2 days. Was in Houston BTW.
    Rhino Thanks. That will give me a starting point.
    530 RWHP, 479 RWTQ
    Jan 2005
    Let me know next time you're here.
    Apr 2004
    Quote Originally Posted by TAQuickness
    Will do.
    530 RWHP, 479 RWTQ
    Dec 2006
    Can I ask you guys a quick question, since I have no speedometer hooked up with my turbo 400, my throttle cracker should never kick in, correct? So i don't have to worry about touching it or the enable/disable speeds, right?
    - Devon
    White '99 Z28
    9.09 @ 150
    Apr 2004
    Quote Originally Posted by Loudmouth LS1
    I would think that is correct. I'm wondering if this might affect other tables where speed is a factor...
    530 RWHP, 479 RWTQ
    Dec 2006
    What other tables ya thinkin about, anything important?
    - Devon
    White '99 Z28
    9.09 @ 150
  1. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
  2. Tuning idle transition with OS5
    By oztracktuning in forum Custom Operating Systems
    Last Post: August 2nd, 2006, 01:15 AM
  3. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 03:58 PM
  4. Idle (Transition) Tuning
    By jfpilla in forum Please Read First
    Last Post: January 9th, 2006, 04:58 PM
  5. Dirk Diggler, Idle Transition
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: December 2nd, 2005, 02:41 AM
