Results 1 to 10 of 11
Thread: Modification history
    Default Modification history
    Have you clicked on the Modification history Tab in the tuning tool??.
    Did you know everything you change is automatically updated and saved?.
    You can search by date or keyword.
    For example, if you changed the Idle Airflow table at some stage but you could not remember when or by how much, you would simply enter the table number 'B4307' into the search box and it will find it in the history list, then you can see when it was modified and by how much!!.
    Don't forget the comments tab too!!.
ID:	47   Click image for larger version.
    Oct 2003
    joel
    Jun 2005
    What I love about the history feature is that you can delete entries...
    If you are a freakish compulsive experimenter like I am, your history could end up
    10:01am
    Changed foo = bar
    10:03am
    Changed bar = fu
    10:06am
    Changed fu = ber
    10:08am
    Changed ber = foo
    10:11am
    Changed foo = fu
    Then I just delete everything but the last one I love it... Really excellent addition (along with the notes feature).
    Hello, my name is Erik and I am a horsepower addict...
    Nov 2003
    I love this feature also.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Jul 2005
    Can you tie comments to a particular update?
    Lonnie
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Nov 2003
    Quote Originally Posted by lplott
    Lonnie
    Yes you can.
    Bill
    Feb 2006
    Can gm change the history with onstar? The first time I hooked up efi was
    Feb 1 and the history had weekly changes listed for the month of Jan!
    It was stuff like odometer corrections, speed limiter changes,torque changes,
    etc. The truck has not seen any dealer since at least August. Any comments?
    Quote Originally Posted by sierradiesel
    The history and comment data is stored in the *.tun file on your PC's hard drive. It is not transferred to your PCM. No one sees it or can modify it except you. If you read out the contents of your PCM again there will be no comments or history.
    It's a great feature, it automatically documents your changes, this'll save a lot of wondering later on, especially if you tend to stay up late and can't remember.
    Stay up late tunning.....never
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
  1. Clearing History
    By Lextech in forum Tips and tricks
    Last Post: June 29th, 2009, 04:50 PM
  2. Requested DTCs for modification (LBZ)
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2007, 04:57 PM
  3. Replies: 2
    Last Post: May 10th, 2005, 09:37 AM
