looking for how the pcm comes up with torque signal. like in the transmission tables in force motor current there is a torque signal that it reads to make pressure adjustments where does it come up with that torque signal. what i am trying to do is use efi live to do trans mission controles with out using it for engines controles (stand alone trans controler) i have a tach rpm and tps working but the pressure is to low at high rpms slips trans i am thinking it needs map signal to help with the torque signal getting ready to try that now any input would be great
