VY ute cal.tun I have installed cos5 with a HSV calibration in my Holden ute. After going through the auto ve process a number of times I know have the Ben maps to 0.99 to 1.01. While I leave the cal file as for auto ve everything runs O.K. However when I reapply PE etc & leave the car in SD mode the idle will start getting rough & the AFR will go up to 20:1. The standard B3647 table commands around 13:1 at this point & I have populated the IAT multiplier table as has been suggested on this forum.
I have attached the cal file here & if someone could have a look at it & tell me where I am going wrong it will be much appreciated.
