Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Getting PCM Locked Message
    Oct 2005
    Found out the reason for the PCM being locked. It turned out that the car has the EC38 series PCM in it. Will have to wait until the boys have the program available hopefully early in 2007.
    Thanks.
    Oct 2005
    I've got the same problem on an 06 6.0 liter Silverado - Seed $0B01
    A little help here ?
    Aug 2004
    What are you selecting for your pcm type? You need to select 99+ ls1 for it.
    Oct 2005
    Why, it is an 06?
    Oct 2005
    OK, that worked ?
    Oct 2004
    Quote Originally Posted by Extinct
    OK, that worked ?
    The year of the vehicle is not as important as the PCM type controlling it all
    Andrew
    EFILive Crew
    Dec 2005
    Default pcm type
    just wanted to say having the picture to match up the pcm when you go to read.program.or scan was a kool idea some one needs a pat on the back for that
    Thanks, glad someone appreciates it
  1. Ignition welcome message
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2008, 11:39 AM
  2. Message Problem
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 21st, 2008, 09:45 AM
  3. Error Message
    By TNRGreene in forum General (Diesel)
    Last Post: June 13th, 2007, 11:30 PM
