Is it necessary as is "highly recommended" in the instructions to uninstall existing EFI Live software (V7.3.2) before you install V7.3.3 and if you do this could you loose any of your files?
04.5 GMC 2500HD SLE D/A 4wd ExCab Shtbox Blue
The install works fine "over the top" of the previous install. I think in the background it does a silent remove anyway. All your custom files will be preserved (tunes/logs etc).
Andrew
EFILive Crew
