Results 1 to 10 of 14
Thread: RR and stock PCM
    Jan 2006
    Default RR and stock PCM
    Whats the correct way to save your tune once your done tuning with the RR and want to swap back to the stock pcm. How do you then flash it into the stock pcm. I clicked or did something wrong today because it took me a few tries to get the stock pcm to work right. I either wasnt ssaving something right or either fashing the pcm wrong.
    Oct 2005
    Save file as per normal and then depending on what OS is in your stock PCM do either a calibration flash or full reflash after you have replaced the road runner with the stock pcm in the car.
    Should be fine.
    Maybe do a full reflash if you have forgotten what was in there.
    2014 VF SV LS3 Maloo.
    Jan 2006
    I got that part down with no problems. I ran into problems when I went to put the stock pcm back in.
    Oct 2004
    Did you need to turn the security stuff back on, or do a relink?
    Andrew
    EFILive Crew
    Jan 2006
    I didnt have to turn off anything or do a relink.
    Oct 2004
    What is your G1201 set to?
    Andrew
    EFILive Crew
    Jan 2006
    I just checked, I had it turned off in the tune already. Thats why I didnt have to mess with it.
    Oct 2004
    Thanks mate. Was going to be concerned if you didn't have to do that
    Andrew
    EFILive Crew
    Member VT LS1 NZ's Avatar
    Quote Originally Posted by Tordne
    Andrew mine is still set to class 2.
    I've never had an issue with security,so therefore I've never done a relink since running RR .
    I thought this would be an issue when I first installed RR but it started right up so I've never given it a second thought.
    856RWHP 408 Supercharged LS1 Holden Commodore.
    Oct 2004
    I did not want to hear that
    Hmm, wonder what it could be then...
    Andrew
    EFILive Crew
  1. Stock 2.2l 98 S-10
    By trudynosports in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: July 6th, 2010, 09:18 AM
  2. GETTING some HP from a stock Gen-IV V8
    By A.O.A in forum Gen IV V8 Specific
    Last Post: June 7th, 2009, 08:57 PM
  3. Stock Bin
    By teddyls1 in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:03 AM
  4. Need stock .bin
    Last Post: September 5th, 2006, 08:25 AM
  5. Is this a stock 02 ZO6 cal?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 16th, 2006, 12:41 AM
