Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: RR and stock PCM
    I still want to know the right way to go from RR back to the stock pcm.
    Oct 2004
    OK
    1) Download tune from stock PCM
    2) Install RoadRunner PCM
    3) Flash RoadRunner PCM with file from step 1 (not going through custom OS's etc. here)
    4) If the car doesn't start change the G1201 setting to None and reflash
    5) Make real time changes until you are completely satisfied with the tune
    6) Read image out of RoadRunner PCM
    7) Install stock PCM
    8) Flash file read from RoadRunner PCM
    9) Change G1201 back to standard (and perhaps do a VATS relink)
    That should do it.
    Hope that helps,
    Andrew
    EFILive Crew
    Thats exactly what I did and the car ran real rough. I ended up taking the stock tune and comparing it to the file I downloaded from the rr and coping the differences over.
    Oct 2004
    Those same differences were included in the file that you uploaded back to the stock PCM originally? That seems VERY strange
    Andrew
    EFILive Crew
  1. Stock 2.2l 98 S-10
    By trudynosports in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: July 6th, 2010, 09:18 AM
  2. GETTING some HP from a stock Gen-IV V8
    By A.O.A in forum Gen IV V8 Specific
    Last Post: June 7th, 2009, 08:57 PM
  3. Stock Bin
    By teddyls1 in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:03 AM
  4. Need stock .bin
    Last Post: September 5th, 2006, 08:25 AM
  5. Is this a stock 02 ZO6 cal?
    Last Post: August 16th, 2006, 12:41 AM
