View Poll Results: What level of integration you would find most useful
Voters
31. You may not vote on this poll
  • Wide band only
    8 25.81%
  • Dynomometer only (i.e. torque)
    0 0%
  • Both Wideband and Dynomometer
    23 74.19%
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Wideband/dyno integration
    Aug 2003
    I vote for integration with the LM-1 from http://www.innovatemotorsports.com
    It beats techedge on both price and features.
    Quote Originally Posted by 66ImpalaLT1
    If it outputs an RS232 serial data stream, while logging then it should integrate.
    Aug 2003
    I will ask Innovate about a real time output on the serial port.
    Aug 2003
    Just read on their mailing list that the next version of Innovates firmware will have the ability to output to 3rd party data loggers in real time!
    Jul 2003
    How soon would this be implemented???
    I emailed innovative and they said that it does output to a serial port...
    even though its not real time one can adjust where it starts and where it ends from the canges in the graph and the TPS... I think..
    Oct 2003
    Paul,
    This would be great, but I have an additional related request. I have onboard analog logging for many devices (boost, Fuel pressure, AF, Alky injection....). I find that real time monitoring is not that realistic and I basically merge the data together with an efilive export and analyze in excel or by hand.
    I would vote for a feature that would allow the import of data so that it could be charted and viewed in a consolidated manner. I'm now using the system timestamp in my logging, so the correlation is very easy (I can see where it would be difficult without that common key). I basically just need a way to define a new PID and import.
    If you do go with real time support, please think about providing the ability to capture more than one input with some type of adapter architecture. In other words, allow people/vendors to write their own real time aquisition adapter and feed data into efilive via a standard Interprocess interface.
    Quote Originally Posted by QUICKSILVER2002
    We will investigate doing that - it does seem like a useful feature.
    The second serial interface will accept almost any serial data format. The structure of the data stream will be configurable down to the byte/bit level.
    Jul 2003
    I just got my QSP-100 4 port serial... so I think we are good to go.. AS long as EFILive supports com 5-9 we are ok
  9. #19
    Jul 2003
    when we'll be seeing this integration? Thanks
  10. #20
    Jun 2003
    any update on the roadmap for this feature?
    I would be in tuning heaven if I could get efilive to datalog my A/F output from my techedge wideband.
    thanks!!!
  1. ALDL Integration
    By limited cv8r in forum General
    Last Post: June 13th, 2010, 07:50 AM
  2. Dyno integration complete
    By GMPX in forum General
    Last Post: October 24th, 2009, 11:41 PM
  3. EGT flashscan integration
    By Truckguy in forum General (Diesel)
    Last Post: September 25th, 2009, 09:28 AM
  4. Dyno Integration?
    By Highlander in forum FlashScan V2
    Last Post: June 15th, 2008, 02:35 PM
  5. Dyno success on Dynolog Dyno
    Last Post: April 2nd, 2006, 12:31 AM
