Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Why do you have to change Theft settings?
    Oct 2004
    Default Why do you have to change Theft settings?
    When ever I have installed and used a RoadRunner I have had to change the G1201 (Anti Theft Configuration) option to None (stock/normal PCM it is set to Class-2 on my car).
    Without this setting being changed to None the car just will not start at all.
    So, I'm interested to try and understand:
    1) Why this is?
    2) Does setting this to None affect anything like the BCM for example?
    Thanks guys
    Andrew
    EFILive Crew
    The PCM and BCM are security linked. If you replace the PCM in a vehicle (without performing a VAT relink) then the vehicle anti theft system will not allow the vehicle to start. That is to prevent someone replacing the PCM with one that has the VATs switched off, in order to steal the vehicle. After all it is a pretty simple job to replace a PCM.
    Oct 2004
    So there is something specific to the RoadRunner PCM that requires this to be set to None then, in Holden's anyway?
    The VAT relink option says it's invalid on a RoadRunner PCM. So I guess it means that my car is less secure (don't tell anyone)
    Andrew
    EFILive Crew
    Oct 2005
    Time to setup the Valet option dude.
    Set max rpm lower than idle and see if it kills start.
    Every time I get back from holiday and try and drive off down the road. I wonder why my car cuts out.. Oh yeah, valet mode! Hehe. I set max rpm to 1200 and MPH to 10.
    2014 VF SV LS3 Maloo.
    Oct 2004
    So.. Did you have to set G1201 to None as well then? I guess it would be preferable to be able to set it back to Class-2 and have the car work as well...
    You can wire me up a Valet switch when you are over next - I've got the PCM connectors ready for ya
    Andrew
    EFILive Crew
    Lifetime Member Doc's Avatar
    Oct 2005
    Interesting Phenomonom, never had it happen in Fbodies, Corvettes, or Silverados that I have put the RR in.
    www.efialchemy.com
    www.greatamericancarwar.com
    Sep 2003
    I have mine in my 2002 monaro and i cant remember having to do this.
    Also had it in another guys 2001 SS and didnt have to do it.
    Cheers
    Oct 2004
    Those of you that have not had to change this, do your RoadRunners have the flash chip also or just the RAM emulator?
    Andrew
    EFILive Crew
    Member VT LS1 NZ's Avatar
    Quote Originally Posted by Tordne
    I've had two RoadRunners one with now the one I have doesn't have the flash chip no problems with either.
    Ive used it in 2000 & 2002 Holden.
    856RWHP 408 Supercharged LS1 Holden Commodore.
    Oct 2004
    And I assume you still have the BCM in your car?
    Andrew
    EFILive Crew
  1. VE SS commodore Anti theft
    By limited cv8r in forum General
    Last Post: May 23rd, 2010, 03:34 PM
  2. Anti-Theft???'s
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: November 9th, 2009, 07:17 PM
  3. Fan settings E38
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: August 14th, 2008, 11:15 PM
  4. Theft disable
    By VHR in forum General (Diesel)
    Last Post: July 7th, 2008, 11:35 AM
  5. PE vs RPM settings
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 12:28 AM
