Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
Thread: Why do you have to change Theft settings?
  1. #21
    Oct 2004
    I don't know why I was able to change mine back to Class-2 after having it not start originally?
    Andrew
    EFILive Crew
  2. #22
    Lifetime Member limited cv8r's Avatar
    May 2005
    Tordne, does your RR have the flash chip fitted or just the emulator? I'll have another play with mine tonight & see what happens.
  3. #23
    Oct 2004
    No flash chip in my, just emulator
    The very first RoadRunner's didn't have flash, then they did, and then it was finally decided that flash was a PITA and taken out again.
    Do you use USB or Bluetooth incidentally (not that that has any bearing on this thread)?
    Andrew
    EFILive Crew
  4. #24
    May 2005
    I've only used the USB cable through the passenger window so far, but I have got the bluetooth. Is there any way to tell if you have a flash chip without taking the PCM apart.
  5. #25
    Oct 2004
    Try and read the PCM out with the Tune Tool through the FlashScan interface - ie NOT connected to the RoadRunner through USB.
    If that works you have the flash, if not you don't.
    FYI, I found that if I connected to the RoadRunner via USB and changed to Flash on the RoadRunner taskbar and performed a read operation it worked, so this is not a valid test .
    Andrew
    EFILive Crew
  6. #26
    May 2005
    Pity Flashscan isn't wireless as well, I could tune my car from my lounge chair .
  7. #27
    Oct 2004
    Well plug the Bluetooth thing in and you can ... Not sure if you know the answer to this.. Does the Bluetooth connection/dongle have its battery?
    Andrew
    EFILive Crew
  8. #28
    May 2005
    Do you mean the bluetooth adapter which connects to the RR.
    'Well plug the Bluetooth thing in and you can ... Not sure if you know the answer to this"
    Please do explain- I have been thinking about this before.
  9. #29
    Oct 2004
    Yeah, I don't have the Bluetooth module for my RoadRunner yet. But I wondered if the Bluetooth module that connects to the RoadRunner end has it's own battery (in which case it would need changing occasionally), or if it is powered from the RoadRunner or car battery somehow.
    Andrew
    EFILive Crew
  10. #30
    May 2005
    From what I understand you need to have the vehicle powered up for the bluetooth to work, so I assume it takes its power supply from the PCM. I will probably be fitting it in the next couple of days,just easier to use the USB cable for now.
  1. VE SS commodore Anti theft
    By limited cv8r in forum General
    Last Post: May 23rd, 2010, 03:34 PM
  2. Anti-Theft???'s
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: November 9th, 2009, 07:17 PM
  3. Fan settings E38
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: August 14th, 2008, 11:15 PM
  4. Theft disable
    By VHR in forum General (Diesel)
    Last Post: July 7th, 2008, 11:35 AM
  5. PE vs RPM settings
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 12:28 AM
