Results 1 to 3 of 3
Thread: 97 Corvette VATS
    Dec 2006
    Default 97 Corvette VATS
    Hello, I am very new here and to LS1 tunning too so I am not familar with a lot of in/outs of the PCM. I just purchesed the V1 tool and I am hoping to program out the VATS on the PCM. The engine is now in a kit car so no BCM is avialable. Is there a tutorial on how to do this or can someone post a quick howto? Supposedly the Kit factory programed it out but a lot of us with earlier years 1997/1998 are having issues. So I am thinking the VATS disable they use does not work on our year.
    I read the PDF manual and it says to set the calibration {G1201} to disable. Is this valid on 1997 vettes?
    Edit--
    I guess while I am at. My PCM came from an automatic tranny and I now use a maunual. Can I download the 97 (manual) stock tune and flash the PCM to get ride of the automatic tranny without issue? I am assuming the computer would be the same?
    Oct 2004
    Just checked a 97 Corvette (manual) calibration and the G1201 is definitely there. I believe that s"should" be all that is required for you
    Welcome to the forum BTW!
    Andrew
    EFILive Crew
    Jan 2005
    Welcome to the forum tracykeyes
  1. Will E38 from 08 Corvette work in 2007 Corvette?
    By Chalky in forum Gen IV V8 Specific
    Last Post: June 5th, 2010, 10:00 AM
  2. E38 VATS will not disable
    By v8vegaman in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2010, 03:29 PM
  3. 1998 Corvette LS1 VATS problem
    By Rewire in forum Gen III V8 Specific
    Last Post: September 12th, 2007, 10:36 PM
  4. LBZ/LMM VATs
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 22nd, 2007, 09:56 PM
