Ok, I just purchased EFI live becuase I am having an issue with LS1 from a 97 vette. It is currently in a kit car so I am not using a BCM. The problem is it sarts then dies after2-3 seconds. Sounded like VATS to me. So I used EFI to check the VATS. It is disabled in the PCM. Now here comes the Expert part!
It appears that when I have an OBDII tool EFILive or other connected to the engine it starts and runs fine. When I remove an OBDII tool the engine goes back to start then die. I tried this numerous times times to validate and it is a fact. When OBDII is connected to a tool the engine runs fine. Very wierd! So I guess my question to you guys is this? Is this older PCM looking for another serial data connection before it will allow the motor to start? If this is correct then is there a way to disable this function or trick it into thinking it is there!
Ok, let the comments and questions fly!! Thanks all.
