Results 1 to 10 of 12
Thread: DFCO settings?
    Default DFCO settings?
    Has anyone played around with the DFCO settings on the LL8 yet? I changed one thing but it didnt do anything as far as I could tell, so I went back to stock. Also, if you have done anything, has your mileage increased (thats what Im looking for now, 14mpg sucks ).
    Jan 2005
    I've not played with an LL8 yet, but I managed to get from 13mpg to 15mpg with fueling tweaks and from 15mpg to 21mpg with DFCO tweaks. I would imagine you could net significant mpg gains as well.
    Thanks for the reply, what exactly did you change with DFCO settings in your car? The LL8 has very few settings to work with (dont know how many you have). There are 6 parameters from B0924-B0929 and include RPM Disable/Enable, MAP Disable/Enable, and Speed Disable/Enable.
    Here is what the values are now:
    {B0924} DFCO RPM Enable 1700.000000 RPM
    {B0925} DFCO RPM Disable 1000.000000 RPM
    {B0926} DFCO MAP Enable 4.708221 PSI
    {B0927} DFCO MAP Disable 3.584727 PSI
    {B0928} DFCO Vehicle Speed Enable 26.000000 MPH
    {B0929} DFCO Vehicle Speed Disable 24.000000 MPH
    Apr 2006
    Still playing with mine. Though I really turned down the disable DFCO to off-idle/coasting < 10mph. Haven't seen any changes this tank yet.
    Jan 2005
    raised my map enable/disable to 40/45 kPa, shortened the re-enable timer to 2 seconds (stock is 5), and all other settings are still stock ('00 Firebird). I will probably raise the minimum speed tomorrow morning as it makes for funky idle transitions when transitioning from a DFCO state.
    Jan 2005
    I've played around quite a bit with DFCO and it has helped gas mileage. Between those changes and other tweaks, I've picked up about 2 miles per gallon. DFCO settings that work, don't make sense when you read the descriptions and the enabler/disabler requirements are significantly different from those in LSx systems.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Jan 2007
    TAQuick, could you copy and paste your DFCO settings for all to see? I am very interested in trying them out, TIA -Jeff
    Jan 2005
    Welcome to the forum wsucowboy.
    It's not a simple copy paste function as the settings span multiple tables. I'll see what I can do get some screen shots for you today.
    Oct 2006
    Quote Originally Posted by ScarabEpic22
    Wife just checked her's the other day and it got 19.4mpg highway , and we always get 17 to 18 city , 06 with 7000+ miles on it .
    But still no tune , no word on when if ever will be able to .
    2006 Trailblazer
    Aug 2004
    Tuned by gm, Can you read and email me the file from your 2006 trailblazer and email it to jessebubb@yahoo.com please.
    Select i5 controller for it when you do the read. Thanks
  1. DFCO settings
    By harascho in forum Tuning For Economy
    Last Post: March 11th, 2011, 05:07 PM
  2. DFCO with ECT
    By vzsv8 in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 02:57 PM
  3. Modified DFCO settings - not getting expected results
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: July 3rd, 2008, 12:58 AM
  4. DFCO with A4
    By aleco99 in forum Tuning For Economy
    Last Post: November 10th, 2007, 11:37 AM
  5. Dfco
    By purrvert in forum Custom Operating Systems
    Last Post: May 27th, 2007, 02:43 AM
