Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Tuning for Economy can be done several ways.
    Aug 2004
    Default Tuning for Economy can be done several ways.
    One way is to increase the Efficency of the engine via timing or removing Slop from the trans.
    The trans Slop is the easiest to fix. Remember though, the more line pressure you run, the more loss you have due to the trans pump being harder to turn.
    Shifting patterns play a big role in the way the vehicle uses fuel. Think of this, When a car goes up a hill, and you see yourself having to press the TPS to 50% or more and the car just boggs down and you keep pressing it in more, Would it have been better for you to just allow a lower TPS vs Downshifting pattern? So as you go up the hill it just either unlocks the converter or performs a downshift to the previous gear. Now the vehicle will climb the hill with ease. You will see that the injector pulse width "Fuel used" will be much less as you climbed the big hill.
    Another route is to use the Custom os3.
    Oct 2005
    And get a real trans.. a manual T56
    2014 VF SV LS3 Maloo.
    Member neil's Avatar
    May 2006
    Default Examples
    Is it possible post an example Jesse?
    That would be great for us newcomers.
    Regards,
    Neil.
    Oct 2005
    Joecar did an excellent autotrans tutorial.
    If you do a search you should find the thread.
    I think the thread has a pdf attached to it too.
    Aug 2004
    Another Secret is to monitor and set up the o2 switching tables to be more fine tuned and tighter. BUT!!!! you have to have the ve and maf tables perfect before you do that.
    The reasoning on that is with the switching from rich to lean, rich to lean to get a "Averaged" stoch wastes fuel if it is on the richer side of things and doesnt spend as much time on the lean side.
    Lifetime Member Rhino79's Avatar
    Jul 2006
    I tuned an 05 Tahoe last week, and I really spent some time on the timing table in the cruise areas and he drove about 300 miles on his trip home and back, he called and told me that his MPG average went up about 2-3MPG!
    Dec 2005
    Will DFCO help fuel economy?
    Jul 2006
    Yes from what I've read, but honestly I haven't tried to really mess with it.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    DFCO and light throttle torque tuning - making a big difference to economy.
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    What kind of things can you do to maximize light throttle torque?
  1. Emission Testing/Ways to Cheat?
    By onegonewild in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 07:08 AM
  2. Inst/Avg fuel economy gauge accuracy after tuning?
    By endo in forum Tuning For Economy
    Last Post: June 21st, 2009, 05:48 PM
  3. E38 fuel economy tuning
    By hymey in forum General (Petrol, Gas, Ethanol)
    Last Post: January 26th, 2009, 12:34 AM
  4. Tuning for economy? This MUST include Auto Trannies then.
    By emarkay in forum Tuning For Economy
    Last Post: March 26th, 2007, 09:13 AM
  5. LPG economy tuning
    Last Post: August 21st, 2006, 10:59 AM
