Results 1 to 3 of 3
Thread: OL-Fault?
Hybrid View
    Oct 2003
    Default OL-Fault?
    Well just as I get my tune finished (for now) and get the WOT PEs rght on my PCM seems to be locked in OL. It starts in OL, warms up, and goes to OL-fault as reprted by Scan. Never records LTFTs cause it never gets there. What have I done ?
    Thanks for any help.
    Bruce
    PowrMax Performance
    100 mm PowrMAF
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Is your MAF fail freq set low?
    Is your MAF plugged in?
    Email me your tune and I'll take a peek.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Oct 2003
    Rick,
    The MAF is and has been hooked up . It reads .9 at idle and seems normal. I have not been trying to run MAFless. When I disconnect the MAF the engine definately notices. No codes, but running 19 to LEAN @idle on PLX. Old tunes where it def. went into CL do not wake it up.
    I will send you the tune.
    Many thanks,
    Bruce
    Still no go after a few hours of trying various stuff.
    Update> looks like a bad 02.
    Update 2> replaced 02s and life is good again.
    Thanks :lol:
    PowrMax Performance
    100 mm PowrMAF
  1. Fault
    By GMLSI in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2007, 04:56 AM
  2. Possible EQ/AFR converter fault in 7.4.2
    Last Post: April 28th, 2007, 09:31 AM
  3. OL-Fault
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2007, 11:07 PM
  4. cam sensor fault
    By dobsons dyno tune in forum General
    Last Post: October 12th, 2006, 02:43 PM
  5. CL-Fault ?
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 18th, 2006, 08:34 AM
