Results 1 to 10 of 10
Thread: cant connect
    Junior Member mickkk's Avatar
    Aug 2006
    Default cant connect
    Help anybody - Just connecting for first time EFI to 2004.5 Duramax to send off stock tune to get new one. Will not get past "EFI Live cannot connect to Flashscan. Disconnect cables and try again" I havetried that 20 times - I must be missing someyhing - anybody any ideas? Thanks Mick
    Senior Member Racehemi's Avatar
    Nov 2005
    Here are a few things to check
    Any lights on your flash scan cable when you try to connect?
    Did you install the latests USB drivers?
    Latest EFILive software?
    Did you select the "LLY ECM" option from the drop down menu?
    Will the scan tool connect?
    Is the scan tool connected when you try to read the ECM?
    Try a different usb port on your pc
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    Aug 2006
    2 Lights continuously flashing OBD and USB. Computor is Toshiba Laptop - new yesterday - EFI is V7.3.2 - black Box says FSP V1.2 LLY ECM is selected - Scan Tool says Interface Cable not connected error 31? - tried both USB's - Regards mick
    Oct 2004
    If you go to Device Manager, under 'Universal Serial Bus controllers' can you see something like FSP... device?
    Andrew
    EFILive Crew
    Aug 2006
    I have the Universal Serial Bus Controllers but no FSP Device in there -
    Download the newest version of EFILive 7.3.3. Then, once install is complete, plug you FS device in and see if it is recognized (should hear the windows "da-ding"). Install the drivers as the drivers install manual says, and then try again.
    Oct 2004
    I forgot to mention that you need to have the device connected when looking in Device Manager... If it is connected and not showing then the problem is that the drivers are not loaded correctly (or at all). If the device is not listed under the 'Universal Serial Bus controllers' section check for it under 'Unknown Devices' also.
    Andrew
    EFILive Crew
    Aug 2006
    Its all ok - with a little help from 9 yo son. Went to new hardware loaded Drivers and bingo - Thanks all anyway. I'm a little backward on the technical side of the computers but nothing like experiencing it yourself - Regards
    Oct 2004
    Glad it's all working... Knew it was going to be the drivers though
    Andrew
    EFILive Crew
    Aug 2006
    Thanks - I appreciate it anyway. You are just a smarter kiwi than this ex one
  1. can not connect
    By Jetmech in forum General (Diesel)
    Last Post: November 29th, 2010, 07:31 AM
  2. Help please trying to connect
    By 5.7senator in forum EFILive V4
    Last Post: November 21st, 2009, 09:02 AM
  3. Can't connect to RR fix
    By DrX in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 26th, 2009, 11:31 AM
  4. V1 won't connect
    By chrisr in forum FlashScan V1
    Last Post: August 24th, 2008, 10:08 PM
  5. HELP: Can't Connect
    By tdzee in forum Tips and tricks
    Last Post: May 26th, 2005, 11:40 AM
