Results 1 to 10 of 11
Thread: Another spreadsheet thread...
    Jun 2005
    Default Another spreadsheet thread...
    I've had a few PM's lately requesting a copy of this. I know spreadsheets have been 'out' for a while since the capabilities of the software continues to improve. However, there are still a few features in here that haven't been incorporated yet that might be useful. Take a peak and LMK what you think. Questions are welcome too...
    (Instructions/explanations are given in cells with a little red triangle in the upper right hand corner.)
    Senior Member NewV's Avatar
    Nov 2006
    Download appears to be an invalid zip file at least for me using WinZip v9.
    2005 CTS-V w/tuner wannabe driver
    Jan 2004
    Opens fine for me using windows XP.
    Jun 2005
    Used WinZip v8.1. Post up/PM your email and I'll send the file.
    Nov 2006
    Quote Originally Posted by SSpdDmon
    svassh@msn.com , thx
    Jun 2005
    Quote Originally Posted by NewV
    You've got mail...
    Nov 2006
    Question - If using the NB tabs should you gather the data 'MAF-Less' like an AutoVE tune or with MAF enabled?
    Question - If you use this without WB, ie NB only would you correct the VE first thru multiple runs then attack MAF or can both be done simulataneously?
    Looks great by the way, wanted the update since you posted it as v2.
    Jun 2005
    Yes, VE tuning is to be done in speed density (no MAF), no DFCO, copy spark high octane to low octane, and if your tune is close enough...disable LTFT's. If you disable the LTFT's, you can ignore pasting them to the spreadsheet since you won't have any LTFT data.
    The VE should be done first just like you normally would with the WB. But unlike the WB, this will only help you dial in part throttle and is only as accurate as the NBO2 sensors allow (which really isn't all that bad).
    Thanks! v2 is just a consolidated version of the two Excel docs I sent you earlier with some added instructions/explanations. I guess it still assumes quite a bit (like your questions and the fact that the user knows how to create maps correctly in the scanner). Best of luck in your tuning efforts.
    Jun 2005
    Update - Per request, I've added the High/Low N Factor to all VE and MAF sheets. If your log has more data for a given group of MAP/RPM or MAF Hz, you can apply a greater weight or correction factor to those cells. LMK if you have any questions.
    Jeff
    Chad - LMK if you think of anything else...
    Jan 2004
    Thanks for the update Jeff. I really like how it is now.
  1. VE Table - Interpolation SpreadSheet
    By Tordne in forum Tips and tricks
    Last Post: April 30th, 2018, 12:52 PM
  2. Spreadsheet location?
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2010, 01:09 PM
  3. Another can't connect thread
    By limited cv8r in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 5th, 2007, 03:32 PM
  4. First Thread
    By TAQuickness in forum Custom Operating Systems
    Last Post: December 11th, 2005, 06:34 PM
