Results 1 to 10 of 18
Thread: Help, my PCM serial number was set to 000000000000
    Default Help, my PCM serial number was set to 000000000000
    Any customer who has had a PCM serial number incorrectly deleted by EFILive, will need to use the newest version of EFILive available here:
    http://www.efilive.com/download.aspx#download1
    That new version will program a pseudo random serial number into the PCM during a full-flash if a blank serial number is detected. Once that is done the PCM can be licensed and reflashed normally by EFILive.
    Obviously that may "waste" a previously used license for that PCM. If that is the case please contact me directly at paul@efilive.com and EFILive will provide a replacement license.
    Member warscout2's Avatar
    Jul 2006
    ya it did the same this to me so i had to use a extra license.
    is this going to effect anything else in my tune
    im using version 7.3.3 build 533
    what is everone else using?
    It won't affect anything else in the tune, it will just prevent you from reprorgamming the PCM unless you have unlimited tuning for that type of vehicle. Otherwise, as soon as the new version is released you will be able to restore the serial number and continue programming.
    Feb 2006
    Paul,
    I got bit by this last night whilst I was trying to upgrade to COS3. I fiddled around for an hour or so with the PCM in dead poll mode and then came and read the Forum + updated the software and firmware (benefit of hindsight!).
    I flashed my old OS and tune back in to the PCM no probs, however when I went to do a full flash of the COS3 it is asking me to licence the PCM??? should I go ahead and burn a licence or am I doing something else wrong (I have a strong track record of doing things wrong )
    Jim
    You'll need to full-flash your PCM again with the latest software to allow EFILive to reprogram a new serial number into your PCM. (although it looks like you have already done that).
    To obtain a replacement license for your FlashScan cable, please send:
    1. the FlashScan serial number
    2. the PCM's serial number
    to me at paul@efilive.com
    If you have any spare licenses on your FlashScan cable you can use one of them to re-license the PCM. Otherwise you'll need to wait until the replacement license arrives. Either way the replacement license will make up for the "burnt" one.
    Note: you can obtain the PCM's serial number in the EFILive Tuning Tool using the menu option Flash->Show PCM info...
    Feb 2006
    Paul,
    Many thanks, I've got a spare license so I'll use that one and send the details over to you.
    Cheers
    Jim
    Feb 2006
    I just got a Truck in from another shop that has the serial zero'd and the Vin was missing. I punched in the VIN which brought up everything but I can not do a full flash to it. Any reason why? Partial flashes work just fine but we want to put a custom os in it.
    We have a commercial V2.
    thanks
    Don
    Quote Originally Posted by slowhawk
    thanks
    Don
    The latest version of EFILive will allow you to full flash a PCm with a '000000000000' serial number. It will replace the blank serial with a generated one.
    Available here:
    http://forum.efilive.com/showthread.php?t=4108
    However, if you have already licensed the PCM then you'll need to use another license once the PCM has been "fixed" by EFILive. If that is the case, send me your details and I'll get the licenses sorted out for you so you are not left one license short.
    Feb 2006
    Available here:
    Thanks Paul. I'm guessing since we have a workshop that lisencing won't be a problem.
    Oct 2004
    Jealous!
    Andrew
    EFILive Crew
  1. Serial number: 000000000000
    By akafred in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 10:41 AM
  2. Pcm serial number requested
    By 97power in forum Gen III V8 Specific
    Last Post: October 16th, 2009, 04:54 PM
  3. RR Blanked (000000000000) VIN Problems
    By JezzaB in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 27th, 2008, 11:10 AM
  4. 06 LBZ PCM Part Number
    By SSTuner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2007, 11:42 PM
  5. Number 1
    By TAQuickness in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 1st, 2006, 03:13 PM
