In AUstralia - the AU flacon is equiped with an obd2 connector - but will not connect with my odb2 scan tool.
I am assumeing its possibly an odb1 EEEV setup utilising the odb2 connector
ie:
Ford Falcon XR8 AU build 6/2000 manual 5 spd
Pins Assignment
1
2 Bus +ve
3
4 Chassis Gnd
5 Signal Gnd
6
7 Iso Signal tx/rx
8
9
10 Bus -ve
11
12
13 eeprom
14
15
16 Battery Volts
One company states there unit uses pin 7 as the ISO pin for dtc's - the pin 13 I was told was for writing to the unit using the ngs star diagnostic unit (Std Ford for eec V tool used in Australia at delaerships)
Has anyone tried connecting an aldl device or scan tool with success to this model variant
Keen to try out the efi live software and want to be able to use it comfortably on my car
any help would be apreciated
cheers
O
